vl-subent-ssdel
(vl-subent-ssdel subentDef
sset)
Removes the subentity subentDef (subent definition
list) from sset (pickset) selectionset; returns sset (pickset)
Arguments |
subentDef (sub-entity definition list) 1 single
subentity to be removed from selectionset, using definition list of
format <subent-definition>, see below |
Return |
sset, ENAME (PickSet), or NIL if sset is not a valid selectionset |
Example |
(setq sel
(vl-subent-select)) |
Remarks |
if subentity is not contained in selectionset, the unchanged selectionset is returned, no error is triggered |
<subent-definition> |
list of subentity type,
subentity index (GsMarker), main entity |
Notes |
please see functions (vl-subentity-select) and (vl-subentity-atpoint) |
