Works with Classic, Pro
Fillets intersections; joins intersecting lines with an arc of any suitable radius.
command bar: fillet
alias: f
menu bar: Modify | Fillet
toolbar: Modify | Chamfer/Fillet |
: fillet
Fillet (radius=0.5000): Settings/Polyline/<Select first entity>: (Choose an entity, enter an option, or enter R to change the radius.)
Select second entity: (Choose another entity.)
Fillets can be applied to intersecting, non-intersecting, and parallel lines.
Fillets are applied to all vertices of a polyline.
Choose an entity, or enter R to change the radius. The following entities can be filleted: |
Choose the second entity. |
Displays the Chamfer/Fillet section of the Settings dialog box:
Fillets the vertices of a polyline; prompts you: Select 2D polyline to fillet - choose a single polyline. You cannot control which vertices are filleted; all are. |
Break - cuts parts out of entities.
Chamfer - chamfers intersections.
Settings - specifies parameters for fillets.
SolidEdit - edits faces, edges, and bodies of solid models.
Trim - trims entities where they cross other entities.
