Works with Pro
Shows volumes and areas of interference between ACIS entities.
command bar: interfere
alias: inf
menu bar: Draw | 3D Entities | Interfere
toolbar: Solids |
: interfere
Select first set of Acis objects: (Choose one or more 3D solids or 2D regions.)
Entities in set: 1
Select first set of Acis objects: (Choose more ACIS entities, or press Enter to continue.)
Select second set of Acis objects: (Choose one or more 3D solids or 2D regions.)
Entities in set: 1
Select second set of Acis objects: (Choose more ACIS entities, or press Enter to continue.)
Comparing 1 solids against 1 solids.Interfering pairs: 1
Create interference solids? Yes/<No>: (Type Y or N.)
Highlight pairs of interfering solids? Yes/<No>: (Type Y or N.)
Enter an option: <Next pair>/eXit: (Press Enter, or type X.)
The interference solid remains in the drawing when the command ends.
Specifies the first set of ACIS entities. Choose one or more 3D solids and/or 2D regions. |
Specifies the second set of ACIS entities. Choose one or more 3D solids and/or 2D regions. The entities in the first set are compared with the entities in the second set. |
Determines whether a solid or region of the interference is created:
The solid or region remains after the command ends. |
Determines whether solids or regions are highlighted:
Steps through pairs of interfering solids or regions.
Press Enter to show the next pair of entities that interfere with each other. |
Type X to exit the command. |
Region - creates 2D regions from 2D entities.
