Works with Pro
Performs Boolean subtraction operations on 3D solids and 2D regions; removes one from the other.
command bar: subtract
alias: su
menu bar: Modify | Solid Editing | Subtract
toolbar: Solid Editing |
: subtract
Select ACIS object to subtract from: (Choose the first set of one or more 3D solids and/or 2D regions.)
Entities in set: 1
Select ACIS object to subtract from: (Choose more ACIS entities, or press Enter to continue.)
Select ACIS objects to subtract: (Choose the second set of one or more 3D solids and/or 2D regions.)
Entities in set: 1
Select ACIS objects to subtract: (Choose more ACIS entities, or press Enter to continue.)
The result depends on the order in which ACIS entities are selected.
Select the sphere, and then subtract the cylinder:
Select the cylinder, and then subtract the sphere:
This command also applies to regions:
Specifies the ACIS entities that will have a portion removed. Choose the first set of one or more 3D solids and/or 2D regions. |
Specifies the ACIS entities that will be removed. Choose the second set of one or more 3D solids and/or 2D regions. |
Union - performs Boolean union operations on 3D solids and 2D regions; adds one to another to form a single entity.
