Works with Classic, Pro
Creates parallel copies.
command bar: offset
alias: o
menu bar: Modify | Offset
toolbar: Modify | ![]()
: offset
Offset: Through point/Erase/<Distance> <0.1000>: (Enter a distance, or type T.)
Select entity: (Choose a single entity.)
Both sides/<Side for parallel copy>: (Pick a point, or type B.)
Select entity: (Choose another entity, or press Enter to exit this command.)
OFFSETGAPTYPE settings variable controls how potential gaps between segments are treated when polylines are offset.
Specifies the distance between the original entity and its parallel copy. |
Deletes the source entity. This option sets the value of the OFFSETERASE settings variable. The status of OFFSETERASE remembered for each open drawing seperately. The value of OFFSETERASE is not saved with the drawing, butreset (Off) when you (re)open a drawing. |
Specifies the offset distance by pointing. When you pick a point at the "Side for parallel copy" prompt, your pick point specifies the offset distance. |
Selects the entity of which to make the parallel copy. Only one entity can be selected; the command repeats automatically so that you can offset additional entities. Press Enter or Esc to exit the command. |
Specifies the side on which to make the offset (parallel) copy.
If the Through Point option was selected, your pick point also specifies the offset distance. |
Places offset copies on both sides of the entity.
The OFFSETGAPTYPE settings variable specifies how possible gaps are filled when offsetting polylines.
Left: OFFSETGAPTYPE=0: polyline segments are
extended to close gaps |
Related Command
Copy - makes copies of entities.
