Specify where the initial focus is.
This attribute specifies the tile that receives the initial focus. The "focus" is the active control in the dialog box-for example, an edit box, a button, or a check box. This attribute is useful for directing the user to the most logical starting point for parameter entry.
string: the tile's key.
Valid Tile
Tell me about...
Programming Overview of DCL (Dialog Control Language)
