Specify the name of a tile, as used by a LISP or SDS function.
This attribute specifies the name by which a LISP or SDS program refers to a tile. Each key must be unique within the dialog box. The string is case-sensitive.
string: a string.
Example
Valid Tiles
Tell me about...
Programming Overview of DCL (Dialog Control Language)
