Create a dialog box. DCL Cluster Tile
This cluster tile defines a dialog box. The name prefix defines the case-sensitive name of the dialog box. This name is required to identify the dialog box within the DCL file.
To access the dialog box within LISP, use the load_dialog(to load the DCL file) and the new_dialog(to display the dialog box) functions, as in the following example:
NOTE When both the label and value attributes are defined, value takes precedence over label.
Valid Attributes
Example
Related DCL Tiles
Tell me about...
Programming Overview of DCL (Dialog Control Language)
