Specify the initial values displayed by a list.
This attribute specifies the default text for a list_box or a popup_list (drop-down list box).
string: a string. Use the \n (new-line) character to separate lines.
Example
NOTE You may use the \t (tab) character to space text into columns.
Valid Tiles
Tell me about...
Programming Overview of DCL (Dialog Control Language)
