: popup_list
Display a drop-down
list. DCL Active Tile
This active tile displays a drop-down list box. Contrary to its
name, the popup_list drops down, not up.
The popup_list
tile first appears as a single line, and more of the list appears
when the user clicks the down-arrow. If necessary, the dropped down
list also includes This tile is useful when dialog box space is
limited.
NOTE By contrast, a list_box tile displays at least two lines of
a list by default, along with vertical scrollbars, if necessary.
Also, a list_box can permit multiple selections, which a
popup_list does
not permit.
Creating and Modifying a Pop-up List with LISP Functions
To create and modify the list displayed by the popup_list tile, use these LISP
functions:
The start_list function takes three
arguments. The key argument identifies the name of the
popup_list tile.
The int1 argument specifies the action to take:
| int1
Meaning
1 |
Change one item in the list. |
2 |
Add an item to the end of the list. |
3 |
Create a new list; the default. |
The int2 argument
specifies the item # to change (the first item in the list is #0);
int2 is only used when int1 is 1. For example:
(start_list "L1" 1
3 ; changes the fourth item in the
list.
- (add_list "string")
To make the change, use the add_list function.
The string argument specifies the text that will be added or
replaced in the list:
(start_list "L1" 1
3 ; Changes the fourth item in the
list.
(add_list "New item")
When start_list is in change
mode (int1 = 1), each call to add_list changes the
same item. When start_list is in add mode (int1 = 2),
each call to add_list adds another item to the end of the
list.
NOTE There are no LISP functions for
inserting an item in the middle of the list nor for deleting an
item from the list.
Valid Attributes
: popup_list {
action
= "(string)";
alignment
= position;
edit_width
= number;
fixed_height
= flag;
fixed_width
= flag;
height
= number;
is_enabled
= flag;
is_tab_stop
= flag;
key
= "string";
label
= "string";
list
= "string";
mnemonic
= "char";
tabs
= "string";
value
= "string";
width
= number;
Example
: popup_list {
action
= "(patternlsp)";
edit_width
= 0;
key
= "PL2";
value
= "Closed\nFilled\nOpen";
list
= "2";
NOTE
- The label
attribute displays the text to the left of the popup list box.
- The value
attribute determines which items on the list are initially selected
or highlighted. The attribute consists of a string of integers
separated by spaces, such as:
value = "0 2
5";
- The first item is #0. A null string "" means no
items are highlighted.
Related DCL Tiles
button
edit_box
image_button
list_box
radio_button
slider
toggle
Tell me about...
Programming
Overview of DCL (Dialog Control Language)
About
Predefined Attributes
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
