Display a vertical list of text, with optional scrollbar and title. DCL Active Tile
This active tile displays a list box. When the user selects an item, it is highlighted. A scroll bar appears automatically when there are more items than the list_box tile is able to display.
To create and modify the list displayed by the list_box tile, use these LISP functions:
The start_list function takes three arguments. The key argument identifies the name of the list_box tile. The int1 argument specifies the action to take:
| int1 | Meaning |
| 1 | Change one item in the list. |
| 2 | Add an item to the end of the list. |
| 3 | Create a new list; the default. |
The int2 argument specifies the item # to change (the first item in the list is #0); int2 is only used when int1 is 1. For example:
L1" 1
3 ; changes the fourth item in the
list.
To make the change, use the add_list function. The string argument specifies the text to be added or replaced in the list:
When start_list is in change mode (int1 = 1), each call to the add_list changes the same item. When start_list is in add mode (int1 = 2), each call to the add_list adds another item to the end of the list.
To end the list processing, call the end_list function as follows:
NOTE There are no LISP functions for inserting an item in the middle of the list nor for deleting an item from the list.
Valid Attributes
Example
NOTE
value = "0 2 5";
Related DCL Tiles
Tell me about...
Programming Overview of DCL (Dialog Control Language)
