(/ number1 number2 ...)
Divide the first number by the following numbers.
This function returns the quotient between the two numbers. If you have two numbers, divide number1 by the number2. If there are more than two numbers, divide the number1 by the product of all the following numbers.
You can use real numbers or integers. Dividing all real numbers returns a real number. The same is true for integers; dividing all integers returns an integer. However if there is a combination of real numbers and integers, the integers are recognized as real, and the result is a real number.
Examples
This expression Returns
(/ 8 4) 2
(/ 6.0 12 5) 0.100000
(/ 600.0 5) 120.000
(/ 8 10 5) 0
(/ 6 -3) -2
(/) 0
(/ 0.5) 0.500000
NOTE A decimal point must be prefixed by a digit. For example, 0.5 is valid but .5 results in the Bricscad message, "Error: invalid argument list."
Tell me about...
(* number1 number2 ...)
(fix number)
(float number)
(rem number1 number2 [number3 ...])
(setq symbol1 statement1 [symbol2 statement2] ...)
LISP Compatibility
Programming Overview of LISP (LISt Processing) Language
