Specify that number's distance from 0 (zero), disregarding direction (positive or negative).
This function returns the absolute value of the number. You can use a real number or an integer. This function takes exactly one argument.
Examples
Code | Returns |
(abs 56) | 56 |
(abs -2.3) | 2.30000 |
(abs -49) | 49 |
NOTES
Tell me about...
Programming Overview of LISP (LISt Processing) Language
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
