Make list do what func says.
This function performs a function to the list. The first argument, function, is either a pre-defined or user-defined function with a quote (') preceding it. The second argument must be a list. This function is useful when building a list dynamically.
Examples
| Code | Returns |
| (apply '/ '(10 5)) | 2 |
| (apply '> '(6 7)) | nil |
Notice that the following are equivalent to the previous examples:
| Code | Returns |
| (/ 10 5) | 2 |
| (> 6 7) | nil |
Tell me about...
(defun [c:] name ([arg1 arg2 ...] / [local-var1 local-var2 ...]) expression)
(lambda arguments expression ...)
Programming Overview of LISP (LISt Processing) Language
