Create a list.
When you want LISP to treat the statement literally, you use the quote function. Quote prevents LISP from evaluating the statement. The single quote symbol (') is used as a shortcut for the quote function; the two are interchangeable.
Examples
| Code | Returns |
A |
(1 2 3 4) |
(1 2 3 4) |
Tell me about...
(lambda arguments expression ...)
(setq symbol1 statement1 [symbol2 statement2] ...)
Programming Overview of LISP (LISt Processing) Language
