Carry out this Bricscad command.
With this function, you can use any Bricscad command within a LISP program. Any of the arguments that follow will be used for that command. Any input needed should be stored as variables using setq. Points should be assigned to variables after using the function getpoint.
Some commands continue past the points you have specified. To exit from a command, type a space within quotes to represent an Enter, thus ending the command.
Examples
| Code | Results |
| (command "arc" '(0 0) '(2 4) '(8 20)) | Using preset points. |
| (command "arc" p1 p2 p3) | Using preset variables. |
| (command "line" p1 p2 p3 " ") | Space to end the command. |
Tell me about...
(defun [c:] name ([arg1 arg2 ...] / [local-var1 local-var2 ...]) expression)
(help [filename [topic [flag]]])
Programming Overview of LISP (LISt Processing) Language
