Determine the last item in that list.
This function returns the last element in a list. The element is not returned in a list, unless the last element is a list, as shown by the examples below.
Examples
| Code | Returns |
| (setq b ' ( 1 2 3 4)) | (1 2 3 4) |
| (last b) | 4 |
| (last '("first" "second" ("third" "fourth"))) | ("third" "fourth") |
NOTE This function should be used with caution. For example, you may want a function to retrieve the z-coordinate of a point. However, there are some cases in which the point contains only the x- and y-coordinates. Your function would accidentally get the y-coordinate. For this reason, it is sometimes a better idea to use a mixture of the car and cdr functions.
Tell me about...
(setq symbol1 statement1 [symbol2 statement2] ...)
Programming Overview of LISP (LISt Processing) Language
