Determine what is the logical AND.
This is a logic function using the Boolean AND. The result is generated via manipulating bits. If a bit is "on," it is denoted by a 1; if it is "off," it shows a 0. When the first bit AND the second bit (in the column) are on, then that bit is on. If the first bit is off AND the second is off, then that bit is off. The AND function requires that all bits in a column be on.
Examples
| Code | Returns |
| (logand 5 7 37) | 5 |
| (logand 13 2) | 0 |
| (logand 27 31 43) | 11 |
Tell me about...
(boole function integer1 integer2 ...)
Programming Overview of LISP (LISt Processing) Language
