Determine what is the logical OR.
This is a logic function using the Boolean OR. The result is generated via bits, similar to the logand function. If a bit is "on," it is denoted by a 1; if it is "off," a 0 is displayed. If the first bit OR the second bit (in the column) are on, then that bit is on. The OR function requires that at least one bit in a column be on.
Examples
| Code | Returns |
| (logior 5 7 37) | 39 |
| (logior 17 5) | 21 |
Tell me about...
(boole function integer1 integer2 ...)
Programming Overview of LISP (LISt Processing) Language
