(ssmemb entity-name selection-set)
Determine whether an entity is in the selection set.
This function determines if the entity, entity-name, is in the selection set, selection-set. This function searches through the entities within the selection set to find if entity-name is included. If it is included, the entity's name is returned. If not, nil is returned.
Examples
Code Comments
(setq sset1 (ssadd)) Creates a new selection set called sset1.
(ssadd ent1 sset1) Adds ent1 to sset1.
(ssmemb ent1 sset1) Asks if ent1 is a member of sset1. Yes, so entity name is returned.
(ssmemb ent2 sset1) Asks if ent2 is a member of sset1. No, so nil is returned.
Tell me about...
(setq symbol1 statement1 [symbol2 statement2] ...)
(ssadd [entity-name [selection-set]])
(ssdel entity-name selection-set)
(ssget [mode] [point1 [point2]] [point-list] [filter-list])
LISP Compatibility
Programming Overview of LISP (LISt Processing) Language
