(ssname selection-set index)
Identify the nth entity in the selection set.
This function returns the name of the entity corresponding to the index in the given selection-set. The index refers to the order in which the entities were placed in the selection set starting with 0: index #0 is the first entity, index #1 is the second entity, and so forth.
Examples
Code Comments
(setq a (ssget)) Creates new selection set.
(setq part1 (ssname a 0) Returns the name of the 1st entity.
(setq part2 (ssname a 1) Returns the name of the 2nd entity.
NOTE The entity names returned aren't actual names like line or arc; they are numeric representations in hexadecimal.
Tell me about...
(setq symbol1 statement1 [symbol2 statement2] ...)
(ssdel entity-name selection-set)
(ssget [mode] [point1 [point2]] [point-list] [filter-list])
LISP Compatibility
Programming Overview of LISP (LISt Processing) Language
