Search that string.
This function finds internal string matches. You can see if a certain string is found, or match it with another string.
For example, if you had a string variable called MYVAR which contained the string "SUPERCALIFRAGILISTIC123\##" and you wanted to see if the characters "FRAG" were anywhere in the string you could use the wcmatch function, as follows:
If a match is found, wcmatch returns T. If no match is found, nil is returned. The wcmatch function is case-sensitive. To find a match, you should use strcase to change everything to uppercase if necessary.
You can use several wildcards for wcmatch:
Wildcard | Definition |
~ | (tilde) Pattern not found in string. |
* | Standard wildcard; can be used anywhere. |
? | Matches for a space held by a character or number; number of question marks (?) must exactly match number of characters or numbers in the string. |
# | (pound) Matches any single number. |
@@ | Matches any single character; may not be a number. |
. | (period) Matches any single non-alphanumeric character. |
(space) Matches one or more spaces. |
[ ] | Matches for any of the characters enclosed in the brackets. |
[~ ] | True only if there are extra characters not included in the brackets. |
[ - ] | (hyphen) Searches within a predefined range pattern. |
, | (comma) The "or" option. |
' | (reverse quote) Read next character literally; use for special characters. |
Examples
Code | Returns | Comments |
(setq N "11234 TROPICANA AVE.#@") | ||
(wcmatch N "~345") | T | "345" is not found in the pattern. |
(wcmatch N "*opic*" ) | T | "opic" is found with anything before and after. |
(wcmatch N "?????????????????????") | T | There are 21 characters, numbers and spaces in this string. |
(wmatch N "#####*") | T | Matches 5 digits, followed by anything. |
Tell me about...
(setq symbol1 statement1 [symbol2 statement2] ...)
(substr string start [length])
Programming Overview of LISP (LISt Processing) Language
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
