Class AcadXline
Member of BricscadDb
The InfiteLine object represents an line extending infinitely in both directions. To create an infinite line, use the AddInfiniteLine method. To access the Ellipse object, use the following methods and properties.
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | BasePoint |
Copy | Color |
Delete | DirectionVector |
GetBoundingBox | Document |
GetExtensionDictionary | Handle |
GetXData | HasExtensionDictionary |
Highlight | Hyperlinks |
IntersectWith | Layer |
Mirror | Linetype |
Mirror3D | LinetypeScale |
Move | Lineweight |
Offset | PlotStyleName |
Rotate | SecondPoint |
Rotate3D | TrueColor |
ScaleEntity | Visible |
SetXData | |
TransformBy | |
Update |
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV are fully owned subsidiaries of Menhirs NV. Copyright © 2001- Menhirs NV - All rights reserved. |
