Donut
Draws circles with width.
command bar:  donut
alias:  do, doughnut
menu bar:  Draw | Donut
toolbar:  Draw 2D | Polygon |
: donut
2Point/3Point/RadTanTan/<Inside diameter of circle> <0.5000>:  (Pick a point, enter a value, or enter an option.)
Outside diameter of donut: (Specify a value, or pick two points.)
Center of donut: (Specify coordinates, or pick a point in the drawing.)
Donuts are made of two wide polyline arcs.
2Point
Defines the donut by two points on its circumference; prompts you:
Width of donut - enter a value, or pick two points.
First point on diameter - enter coordinates, or pick a point.
Second point on diameter - enter coordinates, or pick another point.
The abbreviation for this option is 2P.
3Point
Defines the donut by three points on its circumference; prompts you:
First point on donut - enter coordinates, or pick a point.
Second point - enter coordinates, or pick another point.
Third point - enter coordinates, or pick another point.
The abbreviation for this option is 3P.
RadTanTan
Defines the circle by two points tangent to other entities and the radius; prompts you:
Width of donut: (Enter a value, or pick two points.
Diameter of donut - enter a value, or pick two points.
Select first tangent point - enter coordinates, or pick an entity.
Select second tangent point - enter coordinates, or pick another entity.
The abbreviation for this option is R.
Defines the donut by inner and outer diameter, and a center point; prompts you:
Outside diameter of donut - specify a value, or pick two points.
Center of donut - specify coordinates, or pick a point in the drawing.
Grips Editing
Donuts can be edited directly through grips:
  1. Select the donut. Notice that it has four grips.
  2. Drag a grip to stretch the donut (increase or decrease its diameter).
Circle - draws regular circles.
PLine - draws polyline segments and arcs.
Rectang - draws rectangles out of polylines.
PEdit - edits polylines.
3dPoly - draws polylines with x,y,z coordinates.
Polygon - draws regular polygons out of polylines.
