Inserts images in drawings through the Drawing Explorer.
command bar: image
aliases: expimages, im
menu bar: Settings | Images
toolbar: Images | ![]()
: image
Displays the Drawing Explorer open to the Images node:
Attach image files, or modify their properties,and then click X.
Press F1 to access help.
Attaches raster image files to the drawing; displays the Open dialog box.
Choose a raster file, and then click Open. Bricscad displays the Images dialog box. See ImageAttach command. |
Erases the image from the drawing. You may need to use the Regen command to update the screen. |
Inserts the image in the drawing; displays the Images dialog box. See ImageAttach command. |
Cuts the image to the Clipboard. You can paste it in the Drawing Explorer's Image section of another drawing. It is removed from the current drawing. |
Copies the image to the Clipboard. You can paste it in the Drawing Explorer's Image section of another drawing. |
Pastes images and related data. |
Updates the drawing to reflect changes made in this dialog box. |
Toggles automatic drawing updates:
Displays the details of each image.
Displays the image files as small icons, hiding their details. This is useful when a drawing contains many images.
Displays the relationship between files in an Explorer tree-like fashion. "Current" refers to the current drawing.
Specifies the name of the image. This is usually the image's file name. |
Toggles whether the image is displayed:
Reports the size of the image in pixels, horizontally and vertically. |
Reports the number of times the image occurs in the drawing. |
Specifies the path to the image file. Click the ... button to change the path. |
Reports the path to the image file. |
Grips Editing
Images can be edited directly through grips:
Select the image. Notice that its frame has four grips.
Drag a grip to stretch (resize) the image.
ImageClip - clips images.
| Bricscad™ коммерциализирован Bricsys NV. Bricsys NV и Vondle NV являются полностью дочерними компаниями Menhirs NV. Авторские права © 2001- Menhirs NV - Все права защищены. |
