Toggles the quality of images between draft and high.
command bar: imagequality
transparent: 'imagequality
shortcut: Ctrl
toolbar: Images | Quality
status bar: Images |
: imagequality
Enter image quality setting [Draft/High] <High>: (Type D or H.)
Use this command to reduce the memory used by very large images.
When set to Draft, this command:
Reduces color resolution.
Scales images with large numbers of pixels to reduce resolution and memory footprint.
Toggles the image display quality:
Left: image quality = high; right: image quality = draft.
ImageClip - clips images.
Bricscad™ коммерциализирован Bricsys NV. Bricsys NV и Vondle NV являются полностью дочерними компаниями Menhirs NV. Авторские права © 2001- Menhirs NV - Все права защищены. |
