MText
Places multi-line text in drawings through a dialog box.
command bar:  mtext
aliases:  t, mt
menu bar:  Draw | Text | Multiline Text
toolbar:  Draw 2D |
: mtext
Multiline Text: First corner for block of text: (Pick a point, or enter x,y coordinates.)
Justification/Rotation/Style/Height/Direction/Width/<Opposite corner for block of text>: (Pick another corner, or enter an option.)
Displays a dialog box and text entry field:
Enter text, and then click OK.
Specifies the style.
Choose a style name from the droplist. See Style command.
Font
Specifies the font.
Choose a font name from the droplist; this overrides the font specified by the style. Bricscad can use any font installed on your computer.
To apply a font to just one or two words, highlight them, and then choose the font from the droplist,
as illustrated below:
Height
Specifies the text height.
Choose a preset height from the droplist, or enter a value.
To change the height of a few words, highlight them, and then specify the height.
Bold
Toggles boldfacing of text. SHX fonts cannot be boldfaced.
To apply boldfacing:
  1. Select some or all of the text, and then click the B button.
  2. Repeat the procedure to remove boldfacing.
Italic
Toggles italicization of text. SHX fonts cannot be italicized.
To apply italics:
  1. Select some or all of the text, and then click the I button.
  2. Repeat the procedure to remove italics.
Underline
Toggles underlining of text.
To apply underlining:
  1. Select some or all of the text, and then click the U button.
  2. Repeat the procedure to remove underlines.
Overline
Toggles overlining of text.
To apply overlining:
  1. Select some or all of the text, and then click the O button.
  2. Repeat the procedure to remove overlines.
Color
Specifies the color of the text.
  1. Select some or all of the text.
  2. Click the Color button, and then choose a color from the droplist.
Oblique Angle
Specifies the angle by which to slant the text.
  • Enter an angle, or click the buttons to change the value.
  • Less than 0 degrees - characters slant backwards.
  • 0 - characters are upright.
  • More than 0 degrees - characters slant forwards.
Width Factor
Specifies the width of characters.
  • Smaller than 1 - characters are narrow.
  • 1 - characters have normal width.
  • Greater than 1 - characters are wide.
Character Spacing
Specifies the spacing between characters.
  • Smaller than 1 - characters spacing is tight.
  • 1 - characters have normal spacing.
  • Greater than 1 - characters spacing is loose.
Undo
Undoes the last format applied.
Redo
Redoes the last undo.
Stack Fractions
Stacks text containing special characters: / # or ^.
  •  / stacks vertically (separated by a horizontal line)
  • # stacks diagonally (separated by a diagonal line)
  • ^ stacks vertically not separated by a line (tolerance stack)
To stack fractions, follow these steps:
1. Enter fraction text, such as 3/4.
2. Highlight the fraction text.
3. Click the Stack Fraction button.
4. Repeat steps 2 and 3 to unstack the fractions.
Insert Symbol
Inserts special symbols.
Click the button, and then choose a symbol.
You can enter the symbols directly by typing their codes, such as %%d for the degree symbol.
Field
Inserts a field.
Text justification
Specifies the text justification (alignment) within the bounding box.
Click the button, and then choose an alignment from the droplist.
The icon on the button indicates the current justification mode.
Grips Editing
Mtext bounding boxes can be edited directly through grips:
  1. Select the mtext. Notice that it has two grips.
  2. Drag the grips to perform the following actions:
-MText - places paragraph text.
Text - places single-lines of text in drawings.
-Text - places text and evaluates LISP expressions.
AttDef - defines attribute text.
DdEdit - edits text.
Field - inserts a field.
Updatefield - Updates fields in selected Mtexts.
Style - creates and modifies text styles through the Drawing Explorer.
-Style - creates and modifies text styles through the command bar.
QText - toggles between text and rectangular representations.
Change - changes the position of text.
TxtExp - explodes text into polylines.
Spell - checks the spelling of text in drawings.
Find - finds and replaces text.
Properties - modifies the properties of text.
