-MText
Places multi-line text in drawings through the command bar.
command bar:  -mtext
: -mtext
Multiline Text: First corner for block of text: (Pick a point, or enter x,y coordinates.)
Justification/Rotation/Style/Height/Direction/Width/<Opposite corner for block of text>: (Pick another corner, or enter an option.)
Mtext: (Enter text.)
Mtext: (Enter more text, or press Enter to exit the command.)
Specifies one corner of the rectangle that bounds the text block.
Specifies the other corner.
Justification
Specifies the justification (horizontal alignment) of the text inside the bounding box; prompts you:
Specify text block justification: TL/TC/TR/ML/MC/MR/BL/BC/BR/<Top left> - enter a justification mode.
  • TL - top left
  • TC - top centered
  • TR - top right
  • ML - middle left
  • MC - middle centered
  • MR - middle right
  • BL - bottom left
  • BC - bottom centered
  • BR - bottom right
Rotation
Specifies the rotation angle of the text block; prompts you:
Rotation angle for block of text <0> - enter an angle.
Positive angles rotate the text block counter-clockwise.
Style
Specifies the text style to use for the mtext; prompts you:
Text style to use (or '?') <Standard> - enter the name of a text style.
Enter ? for a list of styles defined in the current drawing. See Style command.
Height
Specifies the height of the text; prompts you:
Height of text <0.2000> - enter a number.
This option is unavailable when the style specifies the text height  .
Direction
Specifies the direction in which the bounding box is expanded; prompts you:
Specify drawing direction: Left-to-right/Right-to-left/Top-to-bottom/Bottom-to-top/Style <Left-to-right (L)> - enter an option:
  • L - text is placed at the left, and expands the bounding box to right.
  • R - text expands the bounding box to the to left.
  • T - text is placed at the top, and expands the bottom of the bounding box.
  • B - text is placed at the bottom, and then expands upwards to the top of the bounding box.
  • Style - returns to the previous prompt.
Width
Specifies the width of the bounding box; prompts you:
Width of text box - enter a value.
When set to 0, the box has "infinite" width.
Mtext
Specifies the text; prompts you:
Mtext - specifies the text; to end the command, press Enter at this prompt.
Grips Editing
Mtext bounding boxes can be edited directly through grips:
  1. Select the mtext. Notice that it has two grips.
  2. Drag the grips to perform the following actions:
Text - places single-lines of text in drawings.
-Text - places text and evaluates LISP expressions.
MText - places paragraph text.
AttDef - defines attribute text.
DdEdit - edits text.
Style - creates and modifies text styles through the Drawing Explorer.
-Style - creates and modifies text styles through the command bar.
Change - changes the position of text.
QText - toggles between text and rectangular representations.
TxtExp - explodes text into polylines.
Spell - checks the spelling of text in drawings.
Find - finds and replaces text.
Properties - modifies the properties of text.
