AttDef
Defines how a block's attributes will be created through a dialog box.
command bar:  attdef
aliases:  at, ddattdef
menu bar:  Tools | Define Attributes
toolbar:  Tools |
: attdef
Enter options, and then click OK.
To create and use attributes, follow these steps:
  1. Use this command to define attributes.
  2. Use the Block command to combine attributes and symbols as blocks.
  3. Use the Insert command to insert blocks with attributes.
  4. Use the AttEdit command to edit the values of attributes, if necessary; use the AttDisp command to toggle the display of attributes in drawings.
  5. Use the AttExt command to extract attribute values to external data files.
Tag
Specifies the name of the attribute; this is the name by which Bricscad identifies the attribute. You can use up to 255 letters, numbers, and punctuation.
Prompt
Specifies the user prompt; this is displayed at the command prompt when the attribute is later inserted in the drawing. You can leave this field blank; Bricscad uses the tag as the prompt during attribute insertion.
Default
Specifies the default value; this is displayed in angle brackets, like <360>. As with other defaults, the user need only press Enter to accept this value.
Text
Text Style
Specifies the text style for the attribute text; choose from one of the styles defined in the drawing. (You can create additional text styles with the Style command.)
Justification
Specifies the justification of the attribute text, such as Center or Fit.
Height
Specifies the height of the attribute text, unless overridden by the text style. Enter a value, or click the button.
Height
Dismisses the dialog box temporarily, and then prompts you at the command prompt:
Select text height - enter a value, or pick two points in the drawing.
Rotation
specifies the rotation angle of the rotation text. Enter a value, or click the button.
Rotation
Select text angle - enter an angle, or pick two points in the drawing.
Attribute Flags
Hidden
Hides the attributes; they are not displayed and not printed. (Hidden attributes can be displayed with the AttDisp command.)
Fixed
Uses the default value; the user cannot change the value.
Validate
Forces the user to enter the value a second time; this helps to ensure the value is entered correctly.
Defined
Inserts attributes without prompting the user; the attributes can be changed later with the AttEdit command.
Insert Coordinates
Insert Coordinates
Select insertion point -enter coordinates, or pick a point in the drawing.
X
Specifies the x coordinate of the attribute's insertion point.
Y
 Specifies the y coordinate.
Z
Specifies the z coordinate.
-AttDef - defines attributes through the command bar.
AttDisp - toggles the display of attribute text.
AttEdit - edits attribute values and properties.
AttExt - extracts attributes from drawings to data files through a dialog box.
-AttExt - extracts attributes from drawings to data files through the command bar.
Block and -Block - create blocks from attribute definitions and entities.
DdAtte - edits the values of attributes through a dialog box.
EAttEdit - edits attribute values and most properties.
Expode - reduces attributes to tags.
Insert - inserts blocks and prompts for attribute values through a dialog box.
-Insert - insert blocks and prompts for attribute values through the command bar.
InsertAligned - inserts blocks repeatedly, and inserts mirrored blocks.
Properties - edits attribute values and properties.
RefEdit - edits blocks and attributes in-place.
