OleLinks
Works with Classic, Pro
Adjusts links of OLE entities embedded in or linked to drawings (short for "object linking and embedding").
command bar:  olelinks
menu bar:  Edit | Links
: olelinks
Change a setting for a link, and then click Update Now.
Use the InsertObj command to insert OLE objects in drawings.
Update Now
Updates linked OLE entities.
When the source file changes, use this button to update the copy in the Bricscad drawing.
Open Source
Opens the source file in the source application. This allows you to edit the source file.
When done editing, choose Update & Exit from the File menu.
Change Source
Changes the source for the linked OLE entity.
Break Link
Breaks the link with the source file. When the link is broken, the OLE entity in the drawing no longer changes when the source file changes.
Source
Reports the path to the source file name.
Type
Reports the file type.
Update
Determines how the OLE entity in the drawing is updated, when the source changes:
  • Automatic - the OLE entity in the drawing changes whenever the source file changes.
  • Manual -  the OLE entity in the drawing changes when you click the Update Now button.
OleOpen - creates package files of OLE entities
PasteSpec - pastes entities in several formats.
InsertObj - inserts foreign (non-Bricscad) objects into drawings
Insert - inserts DWG files in drawings.
ImageAttach - attaches raster images to drawings.
XAttach - attaches DWG files to drawings.
