Plot
Plots drawings to printers and to files, through prompts at the command bar; this command is meant for scripts and routines.
command bar:  plot
: plot
Detailed plot configuration Yes/<No>: (Type Y or N.)
Enter a layout name or [?] <Model>: (Enter a name, type ? for a list of layout names, or press Enter to accept the default).
Enter a page setup name: (Enter a name, or press Enter for none).
Enter an output device name or [?] <default.pc3>: (Enter a name, type ? for a list of device names, or press Enter to accept the default).
Write the plot to a file <Yes>/No: (Type Y or N).
Save changes to model tab Yes/<No>: (Type Y or N).
Proceed with Plot <Yes>/No: (Type Y or N).
Using default plot configuration (default.pc3).
Detailed plot configuration:
Enter an output device name or [?] <dfault.pc3>: (Enter a name, type ? for a list of device names, or press Enter to accept the default).
Enter paper size or  [?] <Letter>: (Enter a name, type ? for a list of size names, or press Enter to accept the default).
Enter paper units <Inches>/Millimeters: (Type I or M).
Enter drawing orientation <Portrait>/Landscape: (Type P or L).
Plot upside down Yes/<No>: (Type Y or N).
Enter plot area <Display>/Extents/Limits/View/Window: (Enter an option).
Enter plot scale (Plotted Inches = Drawing Units) or <Fit>: (Enter a scale factor or type F).
Enter plot offset (x,y) or <0.0000,0.0000>: (Enter x,y offset distance).
Plot with plot styles Yes /<No>: (Type Y or N).
Enter plot style table name (enter . for none) or [?] <bricscad.stb>: (Enter a name, type ? for a list of style names, or press Enter to accept the default).
Plot with lineweights <Yes>/No: (Type Y or N).
Remove hidden lines Yes/<No>: (Type Y or N).
To configure plots with a dialog box, use Print command.
Toggles detailed plot configuration:
  • Yes - prompts you with 16 options; see the options listed below.
  • No - prompts you with six options.
Enter a layout name
Specifies the name of the layout to plot.
  • ? - lists the names of layouts in the drawing.
  • Model - plots the model tab only.
Specifies the name of a page setup.
Enter a name, or press Enter for none.
See PageSetup command.
Specifies the PC3 file for the output device.
  • ? - lists the names of devices available on this computer.
When the default is None, you must specify another name.
  • Yes - plots the drawing to a PLT file.
Bricscad displays the Create Plot File dialog box.
Specify a file name, and then click Save.
  • No - plots the drawing to a printer or other output device.
or
Save changes to layout-name
Toggles saving the plot parameters to the model or layout tab:
  • Yes - saves the plot parameters, which can be used for the next plot.
  • No - does not save plot parameters.
Proceed with Plot
Toggles plotting of the drawing:
  • Yes - plots the drawing.
  • No - does not plot the drawing; exits the command.
Detailed Configuration Option
Enter a layout name
Enter paper size
Specifies the name of the paper size:
  • ? - lists the names of paper sizes available for the plotter.
Enter paper units
Specifies the units used for paper sizes:
  • Inches - shows paper sizes in inches.
  • Millimeters - shows paper sizes in millimeters.
Determines how the drawing is plotted on the paper:
  • Portrait - prints the drawing so that the tall edge is upright.
  • Landscape - prints the drawing so that the short edge is upright.
Plot upside down
Toggles upside-down plotting:
  • Yes - prints drawing upside-down.
  • No - prints drawing normally.
Enter plot area
Specifies the area of the drawing to plot:
  • Display - plots the area shown in the current viewport.
  • Extents - plots the extents of the drawing, ensuring all non-frozen entities are plotted.
  • Limits - plots the limits of the drawing, as defined by the Limits command.
  • View - plots the current view, or a named view. See View command; prompts you:
Enter view name - specify the name of a view.
  • Window - plots a rectangular area defined by the user; prompts you:
Select first corner of window - specify one corner of the rectangle.
Select second corner of window - specify the other corner.
Enter plot scale
Specifies the plot scale factor:
  • Plotted Inches (or Millimeters) - specifies the inches (or millimeters) on the paper.
  • Drawing Units - specifies the number of drawing units (inches, meters, etc).
  • F - fits the drawing to the paper; Bricscad calculates the scale factor automatically.
Enter plot offset
Specifies the offset distance for the print.
Enter positive or negative distances to move the drawing in the x and/or y distances:
  • Positive values - moves the drawing up and to the right.
  • Negative values - moves the drawing down and to the left.
The lower left corner of the drawing is moved by the specified distance.
This is useful when the paper has a title block area that might interfere with the drawing.
Toggles the use of plot styles:
  • On - uses plot styles to determine the look of the printed drawing.
  • Off - does not use plot styles.
Plot styles override lineweight settings.
Specifies the plot style table to use, which assigns properties to "pens," colors, and entities.
  • ? - lists the names of plot styles available in the drawing.
  • . - specifies no plot style.
Toggles the use the lineweights:
  • On - mimics lineweights assigned to the drawing in the print.
  • Off - ignores lineweights.
This option is unavailable when Plot with Plot Styles is turned on.
Remove hidden lines
Toggles removal of hidden lines for 3D drawings:
  • Yes - removes hidden lines.
  • No - does not remove hidden lines.
or
Proceed with Plot
Print - plots drawings through a dialog box.
QPrint - plots drawings using the current settings.
Preview - previews drawings before they are plotted.
ConvertPStyles - converts drawings from CTB to STB plot styles.
Layer - assigns plot styles to layers.
PlotStyle - sets the current plot style.
