Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Toggles the frame around images.
command bar: imageframe
transparent: 'imageframe
menu bar: Images | Display Image Frame
toolbar: Images | ![]()
: imageframe
Displays a dialog box: / Prompts you in the command bar:
Enter image frame setting [ON/OFF] <OFF>: (Type ON or OFF.)
This command applies to all images in the drawing; frames cannot be toggled on individual images.
It also applies to the frames of rectangular and polygonal clippings.
When frames are turned off, images cannot be selected.
Toggles the display of image frames:
Left: Image frame on; right: image frame off.
ImageClip - clips images.
