Class Acad3DFace
Member of BricscadDb
The Face3D object represents a 3D triangle or quadrilateral plane section. To create a 3D face, use the Add3DFace method. To edit or query a 3D Face, use the following methods and properties:
| Methods | Properties |
| ArrayPolar | Application |
| ArrayRectangular | Color |
| Copy | Coordinates |
| Delete | Document |
| Erase | EntityName |
| GetBoundingBox | |
| GetExtensionDictionary | Handle |
| GetInvisibleEdge | HasExtensionDictionary |
| GetXData | Hyperlinks |
| Highlight | Layer |
| IntersectWith | Linetype |
| Mirror | LinetypeScale |
| Mirror3D | Lineweight |
| Move | Parent |
| Rotate | PlotStyleName |
| Rotate3D | VisibilityEdge1 |
| ScaleEntity | VisibilityEdge2 |
| SetXData | VisibilityEdge3 |
| SetInvisibleEdge | VisibilityEdge4 |
| TransformBy | Visible |
| Update | |
