Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Converts drawings to from CTB (color-based plotting) to STB (plot styles).
command bar: convertpstyles
: convertpstyles
Click OK.
The next dialog box appears:
Choose an STB file, and then click Open.
Bricscad reports in the command bar:
Drawing converted from Color Dependent mode to Named plot style mode.
No options.
Layer - assigns plot styles to layers.
PlotStyle - sets the current plot style.
Print - plots drawings with plot styles.
Properties - changes plot styles assigned to entities.
