Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Creates 3D mesh surfaces by connecting two separate linear entities.
command bar: rulesurf
menu bar: Draw | Meshes | Ruled Surface
toolbar: Draw 3D | 3D Surfaces
: rulesurf
Select entity to define first end of ruled surface: (Select an open object.)
Select entity to define other end: (Select another open object.)
Specifies the first boundary line; choose any open object, such as line, arc, polyline, or spline. Closed entities and 3D entities do not work. |
Specifies the second boundary line. |
Grips Editing
Ruled surfaces can be edited directly through grips:
Select the rulesurf. Notice that it has one grip at each vertex.
Drag the grip to move the adjacent faces.
Ai_Dish - draws 3D dishes as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
