Block object
Class AcadBlock
Member of BricscadDb
The Block object represents one or more entities grouped together to create a single entity. The Block definition contains a name and a set of entities. To insert a block into a drawing, use the InsertBlock method. To edit or query a block definition, use the following methods and properties:
Methods Properties
Add3DFace Application
Add3DMesh BlockScaling
Add3DPoly Comments
AddArc Count
AddAttribute Document
AddBox Explodable
AddCircle Handle
AddCone HasExtensionDictionary
AddCylinder IsDynamicBlock
AddDim3PointAngular IsLayout
AddDimAligned IsXRef
AddDimAngular Layout
AddDimDiametric Name
AddDimOrdinate ObjectID
AddDimRadial ObjectName
AddDimRotated Origin
AddEllipse OwnerID
AddHatch Path
AddImage Units
AddLeader XRefDatabase
AddLightWeightPolyline
AddLine
AddMText
AddPoint
AddPolyfaceMesh
AddPolyline
AddRay
AddRegion
AddRevolvedSolid
AddSection
AddShape
AddSolid
AddSphere
 AddSpline
AddTable
 AddText
AddTolerance
AddTorus
AddTrace
AddWedge
AddXLine
AttachExternalReference
Bind
Delete
Detach
GetExtensionDictionary
GetXData
InsertBlock
Item
Reload
SetXData
Unload
WBlock
