Sets or returns the height of following objects:
Application, Attribute, AttributeReference, MText, PViewport, Raster, Shape, Text, TextStyle, Toolbar, Viewport, View
Syntax
Where:
integerVariable is a double variable for storing the Height property.
object is the object this property applies to.
Application: The height of the main application window in pixels. (Integer)
Attribute, MText, Text: The height of the uppercase text. Height is measured in the drawing units. The Height property is used as a scale factor for both the height and width of the text.
Raster: (Read-Only) The height of the raster image in pixels. (Integer)
Viewport: The height of a viewport is the Y axis measurement of the viewport frame.
View: The height of a view is the Y axis measurement of the area within a viewport that is used to display the model.
Examples...
© Menhirs NV. All rights reserved. |
