Creating Blocks
Commands: BLOCK, -BLOCK,  WBLOCK and  PASTEBLOCK
The Block command groups entities into a block using a dialog box. The -Block commands prompts you in the command bar.
The Wblock command writes blocks and other drawing parts to a separate drawing file (short for "write block").
The Pasteblock command pastes entities from the Clipboard as a block in the current drawing (see Paste a selection as a block).
General procedure to create a block
To create a block in a drawing
  1. Do one of the following:
  2. Click the Create Block tool button () on the Tools toolbar.
  3. Choose Create Block in the Tools menu.
  4. Type block in the command bar, then press Enter.
The Block Definition dialog displays:
  1. Type a name for the new block in the Name field.
  2. Do one of the following to specify the Base Point:
  3. Check the Specify On-screen option.
    You will be prompted to specify the base point after clicking the OK button.
  4. Click the Pick point button ().
    The Block Definition dialog closes temporarily to let you pick a point in the drawing.
  5. Type the coordinates of the base point in the X-, Y- and Z-field.
  1. Do one of the following to select the entities to be included in the block definition:
  2. Check the Specify On-screen option.
    You will be prompted to select the entities after clicking the OK button.
  3. Click the Select entities button ().
    The Block Definition dialog closes temporarily to let select the entities in the drawing.
  1. Set the block properties:
  2. Scale uniformly: if checked, the X-, Y- and Z-scaling cannot be set differently.
  3. Allow exploding: if not checked, prevents the block from being exploded.
  4. Block unit: set the insertion unit for the block (see also: To insert a block).
  1. Set the behavior of the selected entities after the block is created:
  2. Retain: The selected entities remain in the drawing.
  3. Convert to block:  The selected entities are replaced by the newly created block.
  4. Delete: The selected entities are deleted.
  1. Click the OK button to create the block.
NOTE
If the selected entities were erased by setting the Delete option in step 6, you can bring back the selected block entities by typing oops in the command bar, then press Enter.
To create a block using the Blocks Explorer
  2. Choose Blocks...  in the Settings menu.
  3. Type explblocks in the command bar, then press Enter.
The Drawing Explorer - Blocks dialog opens.
  1. In the  Drawing Explorer dialog do one of the following:
  2. Click the New button () on the Details toolbar.
  3. Choose New in the Edit menu.
The Drawing Explorer dialog closes.
The command bar reads: Insertion point for new block:
  1. Specify the insertion point of the new block.
    The command bar reads: Select entities for block.
  2. Select the entities for the new block.
  3. Right click to create the block.
    The selected entities are removed from the drawing.
    The  Drawing Explorer dialog reopens.
    The Name field of the new block is selected.
  4. Type a name in the Name field, replacing the default NewBlock1 name.
  5. Close the Drawing Explorer dialog.
  6. (option) Type oops in the command bar, then press Enter  to bring back the selected block entities.
To save a block to a separate file
  2. Click the Save Block... tool button () on the Tools toolbar.
  3. Choose Save Block... in the Tools menu.
  4. Type wblock in the command bar, then press Enter.
The Write Block to File dialog opens.
  1. Click the browse button () next to the Name and path field.
    The Save Block dialog opens.
  2. On the Save Block dialog, select a folder and type a name in the File name field, then click the Save button.
    The Save Block dialog closes.
  3. Insert units: set the insertion unit for the block (see also: To insert a block).
  4. To select the source entities for the new block, do one of the following:
  1. Click the OK button to create the drawing file.
