General procedure for printing
Commands: PLOT, PRINT and QPRINT
The Plot command plots drawings to printers and to files, through prompts at the command bar; this command is meant for scripts and routines.
The Print command prints drawings to plotters and files through a dialog box.
The Qprint command prints the drawing with the default plot configuration, without displaying the Print dialog box (short for "quick print").
Printing
A standard print procedure consists of the following steps:
NOTE
All print settings and options are saved in the Model and each of the Layouts.
To open the Print dialog
Do one of the following:
NOTE
If you click the Print () button in the Standard toolbar, the Qprint command is launched, which will start printing the currently selected view tab using previously saved print settings.
To choose the paper size
Press the down arrow, then select the paper size in the Paper Size list.
The available sizes depend on the selected printer.
To choose the paper units
Select either Inches or Millimeters.
The paper size image indicates the size, position and orientation of the plot area on the selected paper size.
NOTE
The Scale and Plot offset setting units are changed according to the chosen Paper units.
To choose the drawing orientation
Select either Portrait or Landscape.
The paper size image changes accordingly.
When in a layout, click the Apply button to update the display.
To define the plot offset
Select either Center on page
or
type the plot offset in the X: and Y: fields.
The offset is calculated from the bottom left corner of the paper.
To specify the area to plot
Result
View
Prints the portion of the drawing that displays in the current viewport or a saved view.
Extents
Prints all entities in the drawing
Limits
Prints to the limits defined in the drawing
This option is only available when printing in Model space.
Layout
Prints the current layout.
This option is only available when printing in Paper space.
Window
Prints the portion of the drawing contained in a user defined window, maintaining the aspect ratio of the windowed area to the drawing.
Click the Select print area button (), then specify the two corners of the print area in the drawing.
or
Type the the X- and Y-coordinates of the corners of the print area in the X:  and Y: fields.
To define the plot scale
... when printing in paper space:
If you print in paper space, the final scale of the plot output is the product of the viewport scale and the plot scale.
In order to keep control over the scale of the plot output:
Paper units
Drawing units
Plot scale
mm
mm
1
mm
cm
10
mm
m
100
... when printing in model space:
If you print in model space, the scale of the plot output equals the plot scale, on condition your drawing units equal the paper units. Otherwise you need to multiply the plot scale with respect to the relationship between paper units and drawing units.
To set the plot options
Click to toggle the plot options On / Off.
Effect
Plot object lineweights
If Plot with plot styles is off, object lineweights are plotted.
Settings of the assigned STB or CTB file are used.
Plot paperspace last
Entities in Model space are plotted first, paperspace entities last.
Save changes to layout
All changes made in the Print dialog are saved in the layout.
This option toggles the Save changes to layout variable.
Plot stamp
Adds a header and / or footer.
Click the Edit plot stamp button () to define the header and footer.
To define the plot stamp
  1. Click the Edit plot stamp button ().
    The Plot stamp dialog opens.
  2. In the Header field, do one of the following:
  3. Type the header text.
  4. Click the down arrow button, then choose a variable in the drop down list.
  5. Type one or more variable names.
  6. Leave the field empty.
  1. In the Footer field, do one of the following:
Variables
Name
$Name
Adds the name of the current user, as definied in the User Name field of the License Information.
$Company
Adds company name of the current user, as definied in the Company  field of the License Information.
$Date
Adds the current date.
$DateTime
Adds the current date and time.
$DwgName
Adds the file name and path of the drawing.
NOTE
The header and footer text is centered by default.
The header and footer text can be outlined left center and/or right by separating the text with commas.
e.g. $Name,$Company,$Date  places your name left, company name centered and the current date at the right.
In fact the header and footer text consists of three parts, separated by commas. Type a space before one of the commas to leave one of the parts empty, thus outlining the header or footer left or right.
  • $Company, ,  ($Company,<space>,<space>) outlines the company name left.
  •  , ,$Company (<space>,<space>,$Company) outlines the comapny name right.
To specify the number of copies
To see a preview of the plot output
  1. Do one of the following:+
  2. Click the Preview button on the Print or Page Setup dialogs.
  3. Choose Print Preview... in the File menu.
  4. Type preview in the command bar, then press Enter.
  1. (option) Use the mouse scroll wheel to zoom. Double click the middle mouse button to zoom extents.
  1. To close the Print Preview window, do one of the following:
  2. Click the Close button to return to the drawing window.
  3. Click the Print Settings... button to open the Print dialog.
  4. Click the Print button to start printing.
