About X-Hardware
X-Hardware is the premier parametric hardware library for Bricscad. X-Hardware quickly and easily creates 3D fasteners and hardware components with just a few simple mouse clicks. Being parametric, X-Hardware components are easily changed at any time later with either the X-Hardware or X-Solids parametric editing tool. All parts created with X-Hardware are true Bricscad solids virtually indistinguishable from regular Bricscad 3DSOLID entities. Besides working with X-Hardware and X-Solids commands, X-Hardware objects can be used with any of the Bricscad commands that accept solid entities such as UNION, SUBTRACT, ACISOUT, MASSPROP, etc... The familiar Bricscad commands like COPY, MIRROR, MOVE, ROTATE, SCALE etc... can also be used with X-Hardware objects. And, because Bricscad recognizes X-Hardware objects as regular Bricscad 3DSOLID entities, Bricscad Pro or Bricscad Classic users can handle any X-Hardware object without conversion.
