Allows to create and edit render presets, and to set the current render preset through a dialog box.
command bar: renderpresets
menu bar: Tools | Drawing Explorer | Render Presets
: renderpresets
Displays the Render Presets section of the Drawing Explorer dialog box:
Creates a new render preset definition.
Deletes the currently selected user defined render preset(s). It is not possible to delete the predefined render presets. |
Sets the selected render preset current. The current render preset is applied when using the Render command or when printing using the shade plot type Rendered as defined in Shade Plot setting in the Page Setup or the Print dialog. The name of the current render preset displays between brackets: e.g. Current Settings (Medium)? Optionally overrides can be defined in the the editor pane. If
overrides exist, an asterisk displays in front of the current
render preset name: e.g. |
Displays the Detail View of the render presets. |
Displays the Icon View of the render presets. |
Materials |
If On, uses material definitions for rendering. |
Shadows |
If On, calculates shadows. |
Ray Tracing |
If On, calculates ray tracing. Max. depth, Max refections and Max refractions define the number of iterations for ray tracing calculations. |
Processing |
Tile size: sets the resolution of the rendered image. |
Render - generates a photorealistic rendering using materials and lights through a dialog box.
-Render - generates a photorealistic rendering using materials and lights through the command bar.
