BHatch
Fills closed areas with repeating patterns; displays the Hatch and Gradient dialog box.
command bar:  BHatch
aliases:  ba, h, hatch
menu bar:  Draw | Hatch
toolbar:  Draw 2D |
See the Hatch and Gradient commands.
Grips Editing
Hatches can be edited directly through grips:
  1. Select the hatch. Notice that it has one grip.
  2. Drag the grip to move the hatch.
Boundary and -Boundary place a polyline boundary inside closed areas.
Hatch - place hatch patterns through a dialog box.
-BHatch and -Hatch - places hatch patterns through the command bar.
HatchGenerateBoundary - generates a boundary around a hatch or gradient fill.
Properties - changes the properties of hatch patterns.
Settings - specifies the default parameters for hatch patterns.
Solid - draws 3- and 4-side solid-filled areas.
