TableMod
Modifies the properties of a selection of table cells.
command bar:  tablemod
mouse: click a table cell
: tablemod
Pick table cell to edit: click the cell you want to modify or press and hold the left mouse button then define a rectangle to select multiple cells.
Displays a toolbar:
insert row above
Inserts an empty row above the selection.
insert row below
Inserts an empty row below the selection.
delete row
Deletes the row(s) of the selection.
insert column left
Inserts an empty column at the left of the selection.
insert column right
Inserts an empty column at the right of the selection.
delete column
Deletes the column(s) of the selection.
merge cells
Merges the selected cells.
Choose an option:
unmerge cells
Splits previously merged cells.
border style
Sets the border style of the selection (not implemented yet).
text alignment
Sets the text alignment of the selection.
Choose an option:
lock / unlock
Locks / Unlocks the selection.
Click the tool button. BricsCAD responds in the command bar:
Cell contents locked
Cell contents unlocked
cell format
Sets the cell format of the selection (not implemented yet)
cell style
Sets the style of the selected cells.
Choose an option:
cell background
Sets the background color of the selection.
Choose a color,
or click Select Color..., to open the Index Color palet.
Right click
Displays a context menu:
  • Delete Cell Content: deletes the text in the selected cells.
  • Clear Cell Overrides: resets all cell properties of the selected cells to the Cell Style settings as defined in the Table Style.
  • Clear Table Overrides: resets all cell properties of all cells to the Cell Style settings as defined in the Table Style.
Procedures
Editing a table using grips
Editing a table using the Table toolbar
Editing a table in the Properties bar
Editing a cell in the Properties bar
Table - creates a table entity in the drawing through a dialog box.
-Table - creates a table entity in the drawing through the command bar.
Tabledit - edits the cell content.
TableExport - exports the content of a table entity in CSV file format.
TableStyle - creates and edits table styles through the Drawing Explorer - Table Styles dialog box.
