TableStyle
Creates and edits table styles through the Drawing Explorer - Table Styles dialog box.
command bar:  tablestyle
menu bar:  Settings | Table Styles...
: tablestyle
Displays the Table Styles section of the a Drawing Explorer dialog box:
New
Creates a new table style.
Click the TableStyle Name field to replace the NewStyle1 default name.
Delete
Deletes the currently selected table style.
A table style that is being used in the drawing cannot be deleted.
Preview
A preview of the currently selected table style.
Cell Style Settings
Defines the cell style settings for each cell style (Title, Header, Data)
Cell Type
Press the button, then choose a cell style.
The settings for the selected cell style display.
Text Style
Sets the Color, Style and Height for the selected cell style.
Cell Margin
Defines the spacing between the cell border and the content of the cell.
  • Horizontal: distance between the cell content and the vertical cell borders.
  • Vertical: distance between the cell content and the horizontal cell borders
Display
Defines the background color and the alignment.
  • Background Color: pick a color or choose Select Color... to display the Color palette.
  • Align: press the list button, then pick an alignment:
Border
Sets the lineweight and color of the cell borders.
  • Line Weight: pick a line weight in the list.
    Please notice line weights only display if the LWT option in the Status Bar is active.
  • Color: pick a color or choose Select Color... to display the Color palette.
Cell Frame
Click a button to choose an option:
Table Direction
Defines how the table is organized. The options are:
  • Down: Title and header cells on top.
  • Up: Title and header cells at the bottom.
Procedures
To open the Table Styles Explorer
To create a table style
To edit a table style
To apply a style to a table
To delete a table style
-Table - creates a table entity in the drawing through the command bar.
Table - creates a table entity in the drawing through a dialog box.
Tablemod - modifies the properties of a selection of table cells.
Tabledit - edits the cell content.
TableExport - exports the content of a table entity in CSV file format.
Color - specifies the current color, through a dialog box.
Style - creates and modifies text styles with the Drawing Explorer.
-Style - creates and modifies text styles in the command bar.
