TableExport
Exports the content of a table entity in CSV file format.
command bar:  tableexport
context menu: Export Table...
: tableexport
Select Table to export: click a table entity
The Export Data dialog box displays:
If started from the context menu, the Export Data dialog displays right away.
Save in:
Select a folder.
File name:
Type a name for the CSV file.
Default name: <table_name>.csv
Save
Exports the cell data and creates the CSV file.
Cancel
Aborts the TableExport command.
Procedures
To export a table
Defining the list separator character
Table - creates a table entity in the drawing through a dialog box.
-Table - creates a table entity in the drawing through the command bar.
Tablemod - modifies the properties of a selection of table cells.
Tabledit - edits the cell content.
TableStyle - creates and edits table styles through the Drawing Explorer - Table Styles dialog box.
