-Text
Places single lines of text in the drawing, and optionally evaluates LISP expressions.
command bar:  -text
alias:  -t
: -text
Text: Style/Align/Fit/Center/Middle/Right/Justify/<Start point>: (Pick a point, or enter an option.)
Height of text <0.2000>: (Specify a height, or press Enter to accept the default.)
Rotation angle of text <0>: (Specify an angle, or press Enter to accept the default.)
Text: (Enter text, and then press Enter.)
When the TextEval system variable is set to 1, this command evaluates LISP expressions:
Text: Style/Align/Fit/Center/Middle/Right/Justify/<Start point>: (Pick a point.)
Height of text <0.2000>: (Press Enter.)
Rotation angle of text <0>: (Press Enter.)
Text: (* pi 2)
The result of the equation (pi x 2) is placed as text:
Start point
Specifies the starting point of the text.
Pick a point, or enter x,y coordinates.
The starting point is affected by the justification.
Style
Specifies the name of the text style; prompts you:
Text style to use (or '?') - enter the name of a style or type ?.
See Style command.
Lists the names of styles found in the drawing; prompts you:
Text style(s) to list - specifies the styles to list.
  • * - lists all styles.
  • name* - lists all names that begin with name.
  • name - lists the style named name.
Align
Specifies align justification.
Aligns text between two points; prompts you:
Text start point - specify the staring point of the text.
Text end point - specify the end point for the text.
This option supresses the height and angle prompts, because the height and angle are determined by the two pick points.
  • Rotation angle of text is determined by the angle between the two points.
  • Height of text is determined proportions.
More characters in the same distance make the text shorter.
Fit
Specifies fit justification.
Fits text between two points and prompts for the height; prompts you:
Height of text - specify the text height.
This option supresses the angle prompt, because the angle is determined by the two pick points.
Entering certain heights can cause the text to be excessively elongated or squeezed.
Use this justification to force text to fit in an area, such as a closet.
Center
Specifies center justification.
Centers text in the middle of the baseline; prompts you:
Center point of text - specify the center point on the baseline.
Middle
Specifies middle justification.
Centers text on the middle of the text; prompts you:
Middle point of text - specify the middle point.
Right
Specifies right justification.
Right-justifies each line of text; prompts you:
Right point of text - specify the right point on the baseline.
Justify
Displays all justification modes; prompts you:
Text: Style/Align/Fit/Center/Middle/Right/TL/TC/TR/ML/MC/MR/BL/BC/BR/<Start point> - enter an option.
  • TL - top left
  • TC - top center
  • TR - top right
  • ML - middle left
  • MC - middle center (equivalent to Middle).
  • MR - middle right
  • BL - bottom left (equivalent to Start Point).
  • BC - bottom center (equivalent to Center).
  • BR - bottom right (equivalent to Right).
Height of text
Specifies the height of the text.
Enter a number or pick two points.
This prompt is not displayed under the following conditions:
  • Style has set the text to a height other than 0.
  • Justification mode is Align.
If the text style is annotative the height value defines the paper space height of the text; the model space height depends on the current annotation scale as defined by the CANNOSCALE and CANNOSCALEVALUE system variables.
Specifies the angle of the text.
This prompt is not displayed when the justification is set to Align or Fit.
Text
Specifies the text.
Enter a line of text, and then press Enter.
The prompt repeats; enter more text.
Each additional line of text is positioned under the previous line.
Exit the command by pressing Enter at the 'Text' prompt.
Procedures
To create single line text
To create multiline text
Defining text system variables
Grips Editing
Text can be moved directly through grips:
  1. Select the text face. Notice that it has one grip at its insertion point.
  2. Drag the grip to move the text.
Aligned and fitted text have two grips:
Text - places single-lines of text in drawings.
MText and -MText - places paragraph text.
AttDef - defines attribute text.
DdEdit - edits text.
Style - creates and modifies text styles through the Drawing Explorer.
-Style - creates and modifies text styles through the command bar.
QText - toggles between text and rectangular representations.
Change - changes the position of text.
TxtExp - explodes text into polylines.
Spell - checks the spelling of text in drawings.
Properties - modifies the properties of text.
Find - finds and replaces text.
