Find
Searches for text and optionally replaces it; searches through text blocks, attributes, dimensions, and hyperlinks.
command bar:  Find
menu bar:  Edit | Find
: find
Enter text to look for or replace, and then click Find Next.
Find Text String
Specifies the text to be located.
Replace With
Specifies the text with which to replace the located text.
Leave this field empty when only searching for text.
Search In
Specifies the range of search:
  • Entire Drawing - searches all text in the drawing.
  • Current Selection - searches only among the selected entities.
Select Entities
Dismisses the dialog box so that you can select the entities to search; prompts you:
Select entities - choose one or more entities.
Select entities - choose more entities, or press Enter to return to the dialog box.
Options
Displays the Find and Replace Options dialog box; allows you to specify the kinds of text entities to search.
Find Next
Finds the next occurrance of the text string.
Replace
Replaces the found text string with the replacement string.
Replace All
Replaces all occurances of the text string with the replacement string.
Select All
Selects all occurances of the text string.
Zoom To
Zooms to the part of the drawing containing the found text string.
Choose options, and then click OK.
Block Attribute Value
Searches the values of block attributes as well.
Dimension Annotation Text
Searches dimension text as well.
Text (MText, DText, Text)
Searches regular text as well.
Hyperlink Description
Searches hyperlink descriptions as well.
Hyperlink
Searches hyperlinks (URLs) as well.
Match Case
Searches the case of the text:
  • Yes - finds text that matches upper and lower case. For example, searching for "BricsCAD" matches BricsCAD but not bricscad.
  • No - finds all text, regardless of upper or lowercase.
Whole Words Only
Searches for full words:
  • Yes - finds only text that matches entire words. For example, searching for "CAD" matches CAD but not BricsCAD.
  • No - finds all text, including text embedded in longer words.
Procedures
To set the Find and Replace options
To find text
To replace text
Text - places single-lines of text in drawings.
-Text - places text and evaluates LISP expressions.
MText and -MText - places paragraph text.
AttDef - defines attribute text.
DdEdit - edits text.
Hyperlink - adds hyperlinks to entities.
Spell - checks the spelling of words.
Properties - modifies the properties of text.
