DimOrdinate object
Class AcadDimOrdinate
Member of BricscadDb
A linear dimension measuring the absolute X or Y position of a point from the origin. To create an ordinate dimension, use the AddDimOrdinate method. To access the DimOrdinate object, use the following methods and properties:
Methods Properties
ArrayPolar AltRoundDistance
ArrayRectangular AltSuppressLeadingZeroes
Copy AltSuppressTrailingZeroes
Delete AltSuppressZeroFeet
GetBoundingBox AltSuppressZeroInches
GetExtensionDictionary AltTextPrefix
GetXData AltTextSuffix
Highlight AltTolerancePrecision
IntersectWith AltToleranceSuppressLeadingZeroes
Mirror AltToleranceSuppressTrailingZeroes
Mirror3D AltToleranceSuppressZeroFeet
Move AltToleranceSuppressZeroInches
Rotate AltUnits
Rotate3D AltUnitsFormat
ScaleEntity AltUnitsPrecision
SetXData AltUnitsScale
TransformBy Application
Update ArrowheadSize
  DecimalSeparator
  Document
  ExtensionLineColor
  ExtensionLineOffset
  ExtensionLineWeight
  ExtLineFixedLen
  FractionFormat
  Handle
  HasExtensionDictionary
  Hyperlinks
  Layer
  LinearScaleFactor
  Linetype
  LinetypeScale
  Lineweight
  Material *
  Measurement
  Normal
  ObjectID
  ObjectName
  OwnerID
  PlotStyleName
  PrimaryUnitsPrecision
  Rotation
  RoundDistance
  ScaleFactor
  StyleName
  SuppressZeroFeet
  SuppressZeroInches
  TextColor
  TextFill *
  TextFillColor *
  TextGap
  TextHeight
  TextMovement
  TextOverride
  TextPosition
  TextPrefix
  TextRotation
  TextString
  TextStyle
  TextSuffix
  ToleranceDisplay
  ToleranceHeightScale
  ToleranceJustification
  ToleranceLowerLimit
  TolerancePrecision
  ToleranceUpperLimit
  TrueColor
  UnitsFormat
  VerticalTextPosition
  Visible
