StyleName property
Sets or returns the name of the style used with the object
Syntax
stringVariable = object.StyleName
object.StyleName = <string>
where:
     stringVariable is a String representing the style name;
     Object The object this property applies to: Attribute, AttributeReference, Dim3PointAngular, DimAligned, DimAngular, DimArcLength, DimDiametric, DimOrdinate, DimRadial, DimRadialLarge, DimRotated, Leader, MLine, MText, Text, Tolerance.
Examples...
StyleName property example
