Class AcadDimension
Member of BricscadDb
The Dimension object represents a dimension in a drawing. Dimensions may be angular, linear, radial, or one of several other types. To create a dimension, use one of the AddDimXXX methods. To query or edit an existing dimension, use the following methods and properties:
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | DecimalSeparator |
Copy | Document |
Delete | Handle |
GetBoundingBox | HasExtensionDictionary |
GetExtensionDictionary | Hyperlinks |
GetXData | Layer |
Highlight | Linetype |
IntersectWith | LinetypeScale |
Mirror | Lineweight |
Mirror3D | Material * |
Move | Normal |
Rotate | ObjectID |
Rotate3D | ObjectName |
ScaleEntity | OwnerID |
SetXData | PlotStyleName |
TransformBy | Rotation |
Update | ScaleFactor |
StyleName | |
SuppressLeadingZeroes | |
SuppressTrailingZeroes | |
TextColor | |
TextFill * | |
TextGap | |
TextHeight | |
TextMovement | |
TextOverride | |
TextPosition | |
TextPrefix | |
TextRotation | |
TextString | |
TextStyle | |
TextSuffix | |
ToleranceDisplay | |
ToleranceHeightScale | |
ToleranceJustification | |
TolearanceLowerLimit | |
TolerancePrecision | |
ToleranceSuppressLeadingZeroes | |
ToleranceSuppressTrailingZeroes | |
ToleranceSuppressZeroFeet | |
ToleranceSuppressZeroInches | |
ToleranceUpperLimit | |
TrueColor | |
UnitsFormat | |
VerticalTextPosition | |
Visible |
© Menhirs NV. All rights reserved. |
